Cosmid
- Dec 29, 2005
I rip my CDs to computer in lossless format. It is easier if a portable player supports lossless format so I can copy my files to player and it is ready to go.
Yes, indeed it is. But if your source is already jamming instruments together, when you compress if further, the end result is much worse. If you are already limiting the dynamic range, then compressing it to mp3, you further destroy much of the nuances. You start to lose the resonance of the guitars, or violins, bass drums don't have the same impact, and you theoretically have a flatter sound. |
Originally Posted by ubermang /img/forum/go_quote.gif I just wanted to ask people who play lossless files on their portable players. I want to ask them "what difference" they hear. |
Originally Posted by ILikeMusic /img/forum/go_quote.gif No, encoding a track that uses dynamic range compression (and most all do to some degree) will not make the results of the encoding process any better or worse. |
Originally Posted by UseName /img/forum/go_quote.gif Care to explain? |
Originally Posted by ILikeMusic /img/forum/go_quote.gif An encoder will try to provide an audibly transparent copy of the source. There is no technical reason why the amount of dynamic range compression used in creating the source material will necessarily affect the ability of the encoder to do it's job. |
I will revive this thread in 2013 and i'll have a laugh while listening to my 800 CD's of lossless files on random (using only 20% of my 1.5Terabyte Media player) |
