Most of Beagles posts are longer and better thought out. Sadly the post he quoted didnt deserve more of an answer than he gave.
Why is euphonic coloration a nonsense?
This is nonsense because Vinyl does not always sound good, or even better than CD. If the inherent distortions/flaws of vinyl playback were what caused the superior sound there would be a clear edge. Quite a few recent vinyl pressings are simply the CD played into the cutting head. They sound like poo, just like the CD.
You can also buy (perhaps download?) "distortion generators" (hardware and software) to simulate the various flaws of vinyl. Im sorry, you cant pollish a turd (not this easily anyways) - bad CD's still sound bad if not even worse.
The reality of it is that there is nothing special about vinyl except that the people who could hear well and exercised good taste in mixing were around in the 70's. Perhaps the limitations of the medium forced people to be more diligent, or the advent of "easy mastering" has made mastering so easy that anyone can lay down an acceptable (but not always good) mix. Whatever the ultimate cause is for there being more truly high grade recordings from (roughly) 1960-1985 than on CD from 1985 to today there is a clear trend. People simply did it better back then. Perhaps rather than looking at how much dynamic range they can use, or how low the distortion is (whats the THD of a 16Khz sine wave on a 16/44 system? lolerskates at inherent superiority) sound engineers need to look at what they need to do to get consistently good sound. The few who have put out GREAT digital recordings.
In many ways its the same as before, but with more on the lower end:
Before you HAD to be very good to get anything to work. you HAD to know your craft/art. only a few people really did, and they got jobs and mastered tons of stuff.
Now anyone can do it. There are still a few people who are very good, but they are overshadowed by amateur hacks.
To summarize:
The flaws and problems with vinyl are less significant than a generally bad mix, which you are more likely to get off of a CD than a record.
