jjhatfield
Frank
- May 15, 2006
So I'm an iTune's devotee, but I thought I owed it to myself to check out Foobar, since everyone around here thinks so highly of it. Also, I received my Echo Indigo DJ in the mail last night. After some initial problems with trying to stick the Indigo in the wrong slot (story of my life) I sucessfully downloaded the new drivers and got the sucker installed. First off, I love the Indigo, the sound is great (this is just unamped going straight to sr60's, though) but my favorite part is the analog volume control, just for the coolness factor.
I downloaded Foobar, which was quick, then downloaded the ASIO component and the ALAC decoder, dropped them in the components folder. Went to preferences and set the channels for the indigo, and viola, I was off and running. Now, in side by side comparisons with Foobar ASIO and iTunes, I can honestly tell zero difference. BUT, as I said above this is coming from inexpensive non-amped headset. When I get in my k701 and Headfive I'll do more extended comparisons to see if I can tell a difference.
What I'm trying to say is that it was pretty easy, and I might end up finding I enjoy Foobar more, because I love to fiddle with things, and I do like the fact that it starts up really fast and is clean and simple. But, I'm not a convert yet.
I do have a question:
I hear some people rip with a program besides Foobar. Why in the world would you do that? I mean, ripping is ripping, right? If I'm going to choose Foobar for its simplicity, I'd like it to be an all-in-one solution, albeit with lots of *.dll files.
Unless maybe another program rips faster, then I could see the benefit in that.
Currently I'm reripping all my CD's to ALAC, but if I get into Foobar I'll probably go open and rerip FLAC.
Thanks for your input!
