Emon
- Dec 28, 2003
That would only be the case if the system mixer was already at full volume. Since most people don't play at full software volume, there are plenty of "bits left."
Digital systems are very much capable of reducing volume.
That would only be the case if the signal processing was very poorly implemented. The parametric EQ on Winamp or foobar2000 is exactly the same as the parametric EQ done in hardware by my E-MU 1212m. The only real difference is that I can specify the bandwidth with my EMU.
Originally Posted by germanium /img/forum/go_quote.gif The problem with boosting any frequencies digitally with many pop CD's is that they have recorded thier CD at maxed out volumes already & raising any frequence with digital EQ results in clipping unless you put it though a wave editor & reduce the overall volume first by about 10-12db so that you have some room to boost without running out of bits. |
Originally Posted by germanium /img/forum/go_quote.gif If you want to boost any frequencies without reducing the overall volume fiest you need to EQ in the analog domain, not digital!! |
Originally Posted by alpha80 /img/forum/go_quote.gif Lots of Consumer digital EQ's sound awful. |
