Do you definitely have a good seal with the ear tips ?
I don't find the IE600 thin at all but I have read comments where people say that about them.
I do find them fussy in terms of getting tips that seal well because they sit shallow in my ears and bigger tips than usual are needed to fill the wider part of the outer ear canal.
Many complain about the stock tips.
Have you tried plenty of other tips and are perhaps using a size bigger than might be needed on a deep fitting IEM ?
I am using the stock foam tips precisely because the silicone ones don't give me a good seal. It's the most comfortable IEM ever, but since the nozzle is very short it's tough to get the seal. I have not tried other tips, mainly because the foam one seals well, but also because the stock ones have a soft mesh that I am guessing does something to the sound, and I think that if I go to an aftermarket one it might sound different from what the brand intended lol.
I've had them and never noticed it, but I always run on a pretty powerful amplifier. Are you plugging into the 2.5mm balanced to get the full power from it? You can tell fakes on those because the grills are usually grey, not black. Also the tips are rounded and not flat, and the hologram is painted and not a real hologram on the cable splitter. Are you using FLAC? Those are very revealing and a poorly encoded MP3 is going to sound really lame.
Nope, running on 3.5mm. Unfortunately balanced cable that comes with it is 4.4mm, and the stupid Sennheiser MMCX connector prevents me from using my 2-pin Tripowin balanced 2.5mm cable. Quick question tho - can I just plug a 4.4 to 2.5mm adapter to the stock cable and use balanced? If that even exists..
I'm starting to think it's a power issue, here are a couple of thoughts:
1. I'm running it via bluetooth (so limited to AAC) due to convenience. I've done plenty of A/B testing on my desk setup (DX3 Pro+, several IEMs, and my HD6XX) and I honestly can't tell a difference between 320kpbs mp3 (spotify) and hi-res via Qobuz.
2. It's not that the headphone sounds bad. It's just that it needs volume to "open up" the mids, and by the time I get to that volume it's more than I want if I'm looking for relaxing to music. This is of course relative to other IEMs I have, which are the Aful Performer 8 and Softears Studio 4.
3. That being said, just came back from 1h lifting and I was blasting Tim Sweeney's Beats in Space from Apple Music (so 256kbps via AAC), and it was awesome. I pretty much go max volume on the iphone and -4dB on the Q5K, so maybe it is indeed something with power?
I'm going to try A/Bing these "softer", more vocal centric relaxing tracks (i.e. Remember Me from Eivor, or Closer from Ane Brun) from my desktop (DX3 Pro+) which is plenty powerful to see if my impressions remain. Haven't done that before as I only do headphones on my desk setup, and never for critical listening as I'm simultaneously working if I'm at my desk..
