Hi there,
I've been trying to solve an issue that's come up with my Bellari VP130. It's making this high pitched squeal/static that seems to vary and cut in and out. I've tried different tubes, power supplies, and outlets and even using it with nothing plugged in and the problem is consistent. I initially thought it was because of the infamous hum with the unit but after turning on my Vox AC4 it had the same issue with nothing plugged in.
I live in San Francisco, and maybe .5 miles from the Bernal Hill telecom tower and all the rooms here face the street with huge windows. We're also across the street from a hospital and some pretty big powerlines.
Does anyone know if there's a way to stop this squeal/static that seems to impact all tube devices?
Thanks!
Do you have dimmer switches in your home? If so, they are notorious for being an rfi source. To confirm, turn off all your dimmer switches to see if the noise on your amp lessens. Good luck!
