Patrickhat2001
- May 13, 2003
I have a pecular problem on my system--namely it' s that wav files I use (ripped via EAC) don't sound as good as most of the MP3 files I've downloaded. The big problem with the wavs is that they don't seem to have the warmth of many of the MP3s--in all honesty they can sound a little, well honky and thin. Now, of course I've done the obvious which is to make sure that I, indeed, can tell the difference between MP3 and wavs. I've ripped many wav files via EAC and compared them to the same songs ripped in the same manner and encoded as MP3s via LAME (320K CBR). In these situations the wav files always win. But compared to many of the MP3s I've downloaded (I admit by illicit means) the wav files that I've ripped myself seem to lose out--they have better detail and transparency but many times just sound off--kinda honky and thin and, in all honesty, unnatural sounding. Maybe even a bit, I don't know, processed sounding. The MP3s I've made from these wav files also sound like this. I'm I doing something wrong? I have noticed that many of the MP3s I download seem to have a slightly louder volume level which leads me to think that they've been dynamically compressed. Could this be what is causing the difference? Or could I have set something up incorrectly in EAC? I've already made the mistake of not turning off the cache for the for my CD-ROM drive before. Believe it or not but forgeting to turn the cache off caused all of my wav files ripped in such a manner to sound slightly smeered throughout the frequency range and harsh on the top end. Turning the cache off immediately cured this problem but the above mentioned problems still remain. Am I forgetting any to tweak any of the settings in EAC? I've checked the tutorials but everything seems to be set correctly excepting the offsets which I haven't bothered setting up since (as the tutorials say, anyway) their not supposed to change the sound. Anyway does anyone know what could be going wrong?
As for my system I play all my files through Foobar at 24 bit padded to 32 bit decoding at a sample rate of 88.2 Khz (with slow mode enabled). I also use the ASIO plugin (set to time critical and buffer at 0). In all three of my current soundcards--Audiophile 24/96, Revolution 7.1 and Terratec EWX 2496--this problems rears its head. Could I just be experiencing the supposed graininess of mid-fi digital sources?
