audioengr
Member of the Trade: Empirical Audio
- Aug 15, 2004
You got it. Read this white-paper:
jitter
Correct. The timing and jitter is different, even if the data is identical.
Correct also. Depends on many factors in the implementation and the design (these are different things) including the jitter of the master clock (PPM accuracy has little to do with jitter).
This is why customers buy more expensive USB converters and DACs. They sound better than inexpensive ones. Almost everything in the design matters.
Steve N.
Empirical Audio
Originally Posted by AudioCats /img/forum/go_quote.gif Interesting. So jitter reduction is not just a lower-ppm clock module, it has a lot to do with everything else (power quality, wiring, signal reflection in the cable, optical sending/receiving modules, etc)? |
jitter
which means the digital signal from different transports' digital-out are not exactly the same, even if the data stored on the CD is identical and the disk read-out is 100% correct? |
If that is the case, then a flash/harddrive system will still have the same problem, different digital-out will sound different. |
Steve N.
Empirical Audio
