goodsound
- May 25, 2005
Ok one problem solved, another discovered. This is getting more interesting.
Remember I mentioned that the card/driver boosts the spdif input +5db ? Well it is indeed as simple as setting the mixer input level to -5db. The reason I thought this is NOT working is because of the CDP! It is sending incorrect/different sample values!
Long story short, I think the CDP's CIRC is not up to the task. Basically if you rip a track v/s record the track via spdif from a cdp, then those two should be same but they are different in my case.
And when I do a digital(spdif) loopback record of the ripped wav file, the recorded wav file is indeed identical.
I had read somewhere that not all cdps perform CIRC in a proper way. Maybe this is a living example of that ? (another good reason to use 'computer-as-source') ?
