abm0
- Mar 17, 2016
CMRR/crosstalk are the only benefits to balanced yet you can tie the grounds and use a 4-pin connector making the often more expensive balanced moot.
This has been mentioned a few times here, but I still don't get it: if you're tying the two SE amps' grounds together aren't you simply creating the same common mode you set out to get rid of? Or where exactly are you connecting them as opposed to the normal configuration and why does that change anything?
