ooheadsoo
- Dec 11, 2002
The problem is that 2ohm dip that you just posted. Not many amps can handle pushing power out with 2 ohms. I hope that speaker was listed as a 4 ohm speaker at best.
Originally Posted by morphie When you say that wattage isnt what matters, what exactly do you mean? I just bought speakers and a power amp which I will receive soon, the speakers are Dynaudio Audience 62s 160w each and the power amp is a NAD C270 120w/2channels. Could it be that I picked the wrong amp to drive them? |
Originally Posted by Necros Use this a rough guide.. http://www.myhometheater.homestead.c...alculator.html I get 95.8dB in your system..which is very loud, but I guess not much reserve (91dB is very loud during peaks, but usual level would be a few dB below that) With my system I get a possible theorical 117.2dB, that's with the 7 speakers (not excluding sub) Lots of reserve (my average listening level is 88dB) or -20dB after calibration @ 75dB. In 2 channel system I get a maximum of 106.3dB. In use peaks are 90dB, so again lots in reserve.. |
Originally Posted by sacd lover Tube amps are very different than solid state amps into low impedences. Tube amps are high voltage /low current devices while solid state has high current/ low voltage. A tube amp rated for 30 watts into 8 ohms will almost always output the same 30 watts into 4 ohms; sometimes less if the power supply is underspecified. Drop the impedence below 4 ohms and the tube amps output diminishes very rapidly. You might only be getting 10-15 watts into 2 ohms. Solid state on the other hand, again depending on the beefiness of the power supply, will usually double its power output into 4 ohms and even come close to doubling the power again into 2 ohms(think Krell / Mark Levinson). This is why impedence is so important when using tube amps. In the old days speakers were higher impedence with even 16 ohm speakers being common place. For a speaker to work its very best with a lower power tube amp, the speaker needs to have a benign impedence curve and higher sensitivity. ![]() |
