1.
I'm sorry, but, yes. If the speaker has output past 23 kHz, and I can measure that output with a microphone at the listening position, then the tweeter is indeed "delivering ultrasonic energy to the listener" (assuming we're referring to 23 kHz as "ultrasonic").
In the practical world, if we can measure something, and the measurements show it's there, then it's there.
(I would agree that, if it's 20 dB down at 25 kHz, it probably won't be doing anything useful at that frequency.)
2.
Here you go.
Here's a link to our Emotiva Stealth 8 studio monitors.... (they're about $900 each - so cheap by audiophile standards):
https://emotiva.com/product/stealth-8/
They're rated at:
30 Hz to 23 kHz + / -1.75 dB
28 Hz to 32 kHz +0 / -6 dB
And here are the graphs:
http://cdn.shopify.com/s/files/1/0201/8878/t/2/assets/Stealth8_Plot_Graph.pdf
And, yes, their response drops off rather rapidly off axis at very high frequencies (but I usually sit in front of mine).
And, yes, those are real measurements.
3.
As for microphones..... I agree entirely...... and it's up to a whole bunch of people what microphones get used, and where the mixing engineer sets his (or her) filters and EQs.
My only goal is to make sure that MY equipment isn't the limiting factor - so I need to be able to handle anything that they MIGHT include.
(And, yes, in engineering, it's pretty standard to include SIGNIFICANT safety margins to eliminate the possibility of this happening.)
And, yes, if the mixing engineer decides to use a microphone that only hears up to 15 kHz, or even to apply a 10k low cut filter, that's his business - because he's PRODUCING music.
However, if it isn't there because MY equipment failed to reproduce it, then my equipment is broken - because it has failed to REPRODUCE what the engineer put there.
4.
As far as I know the "content" on vinyl
CAN extend to about 60 kHz (I'm defining "content" as "retreivable information").
I read that the pitch stability on some of the Grateful Dead albums reissued by HDTRacks was corrected by locking onto the residual 80 kHz carrier tone from the erase bias - which is still recoverable on tapes recorded on certain master tape machines.
I agree that I have no plans to either use a vintage click remover or restore any antique tapes.....
However, having extra information that I don't ever use is at worst useless, while not having information that I turn out to need later could be tragic.
5.
My point is simply that, if you recorded a CD-4 record directly off the stylus, and later decide to feed that signal to a decoder, it won't work if those frequencies weren't recorded.
This would obviously be a poor method for archiving four-channel content on CD-4 records.
And, again, if you want to claim that you have AN ACCURATE RECORDING of that Cd4 album, then it should be there.
(Or you must concede that you have saved a "processed" copy of the content rather than an accurate copy of the original.)
You have simply decided to set YOUR goal to exclude the requirement of saving all of the out-of-band content in its original form.
6.
I'm not forgetting that at all.
BY DEFINITION, whatever comes off that mastering console is "right".
BY DEFINITION, the job of a "high-fidelity reproduction system" is to reproduce whatever I play through it accurately and completely.
I absolutely agree that we have no provenance, and that it's a problem.
However, while I can't fix that problem, I can at least make very sure that I don't cause unnecessary damage or alteration.
I can only provide quality assurance on the parts which I control.
7.
If you're really trying to say that "damage is OK" then I guess we'll just have to agree to disagree.
In most situations, if a perfect example is available, it will be valued more highly than a damaged one.
That doesn't rule out the possibility that there may be no undamaged examples available, or that a certain damaged example might not actually be considered better than a perfect one for other reasons.
However, I don't think you'll find many dealers of legitimate antiques who would suggest deliberately breaking a vase, and then gluing it back together, as a way to increase its value.
Of course the price will be DIFFERENT if it's damaged.... and, of course, if you prefer to pay less for the damaged one, then that's your choice.
(Try putting up two ads on eBay - of the same vase - describe it in one as "perfect" and in the other as "broken - but with a perfectly invisible repair" and see which one goes for a higher closing bid.)
It occurs to me that this provides a perfect analogy to how *I* feel about both lossy compression and storing music in any format that is designed to carefully avoid storing any level of quality that isn't strictly and provably necessary.
To ME, that would be as if I had an undamaged vase which I needed ship, and someone were to suggest: "If you break it into pieces it will fit in a smaller box and be cheaper to ship. We can glue it back together at the other end and
none of our customers will be able to tell the difference.... so what's the harm?"
8.
The reason I bring up lossy compression is the same reason that your favorite studio does NOT store their masters using it.
In order to "work", and deliver a "virtually indistinguishable" copy of the original, virtually all lossy compression relies on a whole bunch of assumptions and given conditions.
Feel free to suggest that, "in order to hear the noise floor on a CD I would have to turn my system up so loud that the loud parts would deafen me".
However, you seem to be ignoring the fact that I might decide to turn the volume way up on a quiet part to hear what one of the musicians mumbled under her breath.....
Are you suggesting that it is INVALID for me to do so?
Or are you simply suggesting that YOU wouldn't do it?
JPeG is a remarkably effective lossy compression for images; but NOBODY sane would use it as an archival format.
The reason is that, while JPG images may be "visually perfect copies of the original" under certain circumstances, that isn't true under ALL conditions.
Try boosting the contrast, or looking a little too closely at one tiny spot on the picture, and you often notice the flaws.
And, if you were to try and edit that picture, it's a virtual certainty that you'll "run into the limitations" caused by discarding all that data.
Of course, in real life, we always have to choose a set of requirements that suit US.
Someone who favors 24/96k as a recording format will be quick to point out that reducing the sample rate to 16/44k is obviously a form of lossy compression....
You are discarding information which cannot be gotten back.
I guess it also qualifies as "a perceptual lossy format" since you decided what was OK to throw away based on what you can hear - and what you expect me to be able to hear.
9.
As for ANALOG masters, since there's a format conversion involved, there is no direct comparison.
You may prefer that the tape hiss be omitted; someone else may insist that it be reproduced ACCURATELY.
(Just as, in video, some people prefer a smooth background, while others delight in figuring out what type of film was used by the original camera crew by examining the shape of the noise grains.)
Back in the analog days, it was IMPOSSIBLE to own a perfect copy of an album, because every copy process added a small amount of error.
Digital technology now makes it POSSIBLE for every customer to own an actual IDENTICAL copy of that original digital master.
To me, it seems like some sort of blasphemy to throw that opportunity away just to save a few bytes - or a few dollars.
It it seems as if I'm not overly concerned with whether they difference is "audible" or "significant"... then you're right.
I simply see no reason to forego "perfect" and go out of the way to look for an alternative which is "not perfect - but I'l never hear the difference".
I also do find it very sad that all of the attempts to claim to provide provenance have turned out to be either overreaching or just plain impractical.
I think it would be great if I COULD really buy a file knowing that it was a legitimate bit-for-bit copy of what came off the mastering engineer's console.
(Clearly the fact that so many companies promise it - even though they routinely fail to deliver on their promise - suggests that a lot of people agree.)
I'm also going to disagree with you on your definition of the word "practical".... simply because it is a word associated solely with personal opinion.
You seem to consider 24/96k to be "not practical".
I define 24/192k as quite practical - because almost all of the DACs I currently own support it (but I consider 32/768k to be a bit impractical with current equipment).
(Note that nothing was said about "necessary" - which is a different value judgment.)
1. So, you're going to apply that same warped logic here too? If a tweeter has output past 23kHz, then it produces ultrasonic energy? Under that definition EVERY tweeter produces ultrasonic energy! That's true in the absolute, false in the practical. We live in a practical world.
2. OK, you work for the manufacturer. How about a set of polar plots of your "flat to past 25kHz" speakers, then? Or link to manufacturer's data. Any evidence at all would be great. From what I've seen, and I've searched this oh just a bit, "flat past 25kHz" is a very, very tall order, especially when you look at dispersion and power handling too. But I'll take those polars when you have them. Then we can talk about off axis HF response of tweeters, microphones and oh yeah, ears.
3. Look again. Very few are flat past 20kHz. Very, very few. And they'd need to be located in the ultrasonic field of some instrument producing ultrasonic energy to pick it up and transduce it. No, the mic problem is not small, it's huge. But, clearly, we're still at the same warped logic, "if one mic has response flat past 20kHz then a mic can transduce ultrasonic energy". I own a calibrated measurement mic flat to 30kHz, but I'd never use it to record anything. Microphones are part of the sonic palette, we don't select them because they are flat to 30kHz, we select them because their sonic signature compliments the application.
4. I already clearly outlined that old click removers needed extreme HF information, and that modern software works differently and much better. You can worry about "someday", that's fine, but if there's no content at 92kHz, even from clicks (there are actual physical reasons for this), you're just blindly throwing technology at a non-problem.
5. Do not confuse the 45kHz response necessary for recovering the CD-4 carrier (FM, BTW), with the ability of vinyl to reproduce ultrasonic audio content. The two functions are completely and radically different. The CD-4 carrier was injected at very low level, of physical necessity, and was frequency modulated. When played the demodulator would "capture" the carrier with a phase locked FM demod, which effectively ignores the rather poor and ragged amplitude response of vinyl at 45kHz. That's completely different than actually playing real ultrasonic content directly, and unrelated except that CD-4 stylus design pushed stylus shape development forward. You do know the CD-4 groove had to be bigger, right? Less playing time, but it had to be just to get that ultrasonic carrier on and off the disc without damaging it. We don't use that size groove on any other kind of record. Once again, a poor example.
6. But you ignore the fact that any high resolution file has also passed through a mastering phase where those in charge will make it sound differently if they intend it to be a perceived improvement. And that has nothing whatever to do with resolution. Potential for better sound from high-res has yet to be clearly proven, and cannot be proven by consumers buying files because there is absolutely no provenance.
7. Well...my other profession is an antique dealer. No, not kidding. My wife has been a dealer for 34 years, and I joined her in the business about 15 years ago. Now, isn't this fun? I can tell you several things are amiss here. There are virtually no antiques of any kind that are perfect. Damage usually reduces value, but not always. Sometimes certain damage increases value! Repairs reduce value often, but not always. Certain repairs increase value too. The value of an antique is a complex function of rarity, desirability, condition and the market which is comprised of at least two or more buyers. In your example you seem to assume all the vases were identical in every aspect except for the damage and repair. That's a condition that never occurs in the reality of antiques! They would all be different, and you'll buy the one you like if you can accept the price and condition. You won't pay extra for the undamaged vase unless it happens to be the one you like, and at that point, damage is no longer a factor if it is minor or well repaired.
8. Why are you bringing up lossy compression??? Tangential at best. We all prefer the least damaged audio file, but at some point the lossy codec becomes fully transparent, and it no longer matters. Oh, sorry, if one person on or off the planet can detect the codec, then it's bad, right?
Thank you for mentioning that the bulk of high-res files are upsampled or analog masters, which fully disqualifies them for the classification of high-res, and casts doubt on the entire high-res file market for being scam artists.
9. Yes, and those that are different could be made to sound the same different way at standard res.
