Filipe
- Nov 30, 2001
I'm looking for a sound card to put in my PC to be used pretty much only with headphones (beyerdynamic Dt250-80ohm) to listen to CD's, MP3's and radio via the net.
I was looking at the VideoLogic SonicFury and the Hercules Fortissimo 2 which i can get either for arround £50.
Are these cards an overkill since I'll be using them for headphones only?
Are there any sound cards at this sort of price (under £50/$70) with conventional analogue RCA outputs?
Is there a sound card to be used specifically with headphones.
Do any of them work better with headphones than others?!
Cheers
Fil
Cheers
Fil
