rjoseph
- Apr 10, 2009
I was wondering if I could solicit your views on what would work best for me. I'm a noob to headphones and headphone amps. Maybe these questions were asked before but I implore your patience.
Here is where I'm at. I first bought an ATH-m50 and love it. Use it out of my 2nd gen iTouch and it works great. With the greed to add on more, though in small increments, I bought a Fiio E5 hoping it would somehow make a difference. After using it I find it is better to use the m50 straight out of the itouch than using in conjunction with the E5. Maybe the built-in itouch amp is powerful by itself.
Next, on an impulse I bid for and bought a K501 on ebay. When I tried it though, it sounded weak straight out of the itouch and the computer. Expected since it needs a good amp to drive it. My problem statement is that I dont want to invest in another DAC/amp unless I really need to. Can I get away with a viable solution from one among the equipments I have listed below?
My questions are:
1. My computer's sound card says its a 'Realtek High Definition Audio' card. The link to it is here. It site seems to suggest that the card has a DAC built into it. My comp also has a digital line out. Does this really mean I can use the audio out as a DAC and I do need a dedicated one? Granted the sound seems good but does not do anything to the K501.
2. I had long back bought a creative xdock to wirelessly hook up my ipod to my denon receiver. Link here. Thought it has a mini usb slot, it is not directly recognized by the computer. I plug in the speaker out and am able to use it on the computer. Using the K501 with this setup does make the volume a tab bit louder but nowhere as close to what it does with the m50. Can the xdock be used as a substitute to an amp?
3. I also have a denon home theater system. The Denon 488ba listed here. When i plug the K501 or the m50 to the headphone jack of the receiver the sound out is very faint. Sound to the regular speakers are fantastic. I was hoping to capitalize on this setup. But I read in one of the threads that receivers made after the 1990s sound weak when connected to a headphone.
I really do not want to spend more than I need to. And going by the reviews I am devloping a soft corner for the denon ah-d2000/5000. Will any of my existing equipments help me overcome the amp dilemma? If inevitable, which dac/amp doe you think will work best for me based on the cans that I have and intend to buy?
Looking to your feedback/suggestions. Thanks.
My questions are:
