raymond1035
- May 29, 2014
Should i use pink noise only or use white noise-pink noise-brown noise-frequency sweeps? And what volume level do i use? Using an ipod nano.
Conclusions
Have I shown that break-in exists? No. I wish I could say the slowly descending IMD products is clear evidence ... but it's not. Who knows what that measurement represents. I do think, however, that if break-in is measurable, it would be this type of measurement that would show it. I'm pretty happy something showed up at all.
Have I shown that break-in doesn't exist and is not measurable? No. The slight changes around 9kHz on the CSD plots, and the significant change in IMD products over time do indicate that something is happening, and happening in a way that seems to me to be properly indicative of the things I've heard with break-in effects. I think the nay-sayers need to acknowledge something might be happening here.
The one thing I think I have proved, however, is that if break-in does exist, it is not a large effect. When people talk about night and day changes in headphones with break-in, they are exaggerating. This data clearly shows that the AKG Q701 --- a headphone widely believed to change markedly with break-in --- does not change much much over time.
My hiking boots break-in; my sneakers break-in, too. But my hiking boots aren't going to turn into sneakers over time. This idea that you simply must let headphones break-in before you know what they are going to sound like is a myth. And this data busts it.
Until then, you can unbox you new headphones and have a listen without angst. You'll be hearing pretty much how they will forever sound. If you notice they're a bit irritating in the mid-treble, you might find that settles out somewhat with use and the headphones may deliver a mildly more pleasant listening experience.
If you do want to break-in your cans, I suggest pink noise at a slightly louder than normal listening level. If you don't have a pink noise track, just play music. If they sound lousy out of the box, but they start sounding a lot better as you listen to them over time, it's your amazingly versatile brain figuring out how to cope with the world.
The miracle is in your head ... not in the headphones.
