From a technical point of view (not particularly interested in potentially biased human hearing test unless its ABX/blind) which is superior out of: coaxial, USB, or optical?
AFAIK: USB is the only one which can do 32bit, but until we have true 32bit or even full 24bit recordings and DACs which will actually utilize the 24/32bits; I don't see that as relevant.
Essentially it comes down to which one has the lowest jitter? And the implementation?
For my own information:
I have desktop PC which probably instead ideal for noise as its geared towards high performance (Ex TOTL CPU, GPU, Mobo)
I also have an ASUS STX II which can output SPDIF coaxial.
Which one should I use?
Also which bit-rate and sampling rate should I use in windows? Running 24 bit with 16 bit "recordings" (sine waves for tests) shows the noise floor is lowered by over 10db (Cant see due to accuracy of measuring device: Rohde and Schwarz Upv).
