dario
- Aug 23, 2008
Hello I'm Dario, I'm italian (sorry for english
) I'm in search of a dac\amp for the 595, I would like to use the dac with the PC (with it's digital output) and also for other sources, and the amplifier to use for the 595 and a probable with a cowon d2 pc ect and of course also for other uses.
I have seen that these two dac\amp are the best solutions quality\price (not I would have problems to choose DAC and amp separate if I gave more quality at the same price), but between the two what would be the best choice?
And between modded version of the two?
The Zhaolu 2.5 is out of producation right?
The amp section of te both dac\amp is sufficient for quite every HP on the market?
Thanks, Dario.
P.s But if I want to use also two stereo speakers, I must buy a bigger amplifier and connect it to a line out (without the amplification stage of the dac) or amplified speakers or with good efficiency speaker I can use directly the amp section of the dac?
P.p.s Mainly I like rock, but I listen a little bit of everything.
Thanks, Dario.
