GreenEggs313
- Sep 18, 2004
you got that right.
SR-60 on an ipod sounds painfully bright unless you use the "Treble Reducer" EQ setting. And even then, there isn't alot of bass because of the iPod's problem with very low-impedance headphones.
For heavy metal I'd say that the Portapro is better when the source is an iPod.
Originally Posted by EdipisReks get the SR-60's, but only if they are going to be used for non portable use a lot. for portable use i really prefer my PortaPros to my SR-60's. |
you got that right.
