which are<The Best> toroids?
Feb 7, 2003 at 11:46 PM Post #16 of 19
Module.jsp
(put your pointer over the "X", do a right click / properties. copy. control N. highlight address, right click. paste. return (carriage return) or hit the Go button).
otherwise it's a 223-8229 2x30V 5amp £23.16
technical specification
rated VA / regulation % / temperature rise °C / dimensions (Dia. / H.) / fixing bolt / wt ( kg )
15 16 26 60 31 M6x40 0·3
30 18 40 70 32 M6x40 0·45
50 14 42 80 33 M6x40 0·65
80 14 53 93 38 M6x50 0·9
120 10 52 93 46 M6x60 1·2
160 9 55 105 42 M6x50 1·5
225 8 60 112 47 M6x60 1·9
300 8 60 115 58 M6x70 2·3
500 6 68 136 60 M8x70 3·5
625 5 67 136 68 M8x80 4·3
800 5 69 162 60 M8x70 5·1
1000 5 72 162 70 M8x80 6·5
Feb 8, 2003 at 3:36 PM Post #17 of 19
Pinkie you got me
As I don t have a standard Creek to do a A-B comparison I ll do the ..”memory” review.Its got 150+ hours now and almost everything is improved.I ll post my thoughts to Head-Fi too.BTW I believe that it already sounds better than the Headroom Home I had for a couple of years until recently especially with my Grados.The “Pinkie Caps”Creek plus Grado 325 is an eargasm rock combo
As for the Krell since it belongs to my buddy he will decide what toroid to use.He doesn t mind paying more he only wants “the best”.Just to tell you that he wants to build the PSU enclosure from solid granite!
He is the guy who did the job with your caps Mike
Feb 8, 2003 at 8:48 PM Post #18 of 19
if he wants the best, chances are he'd have to use separate power supplies and use a common ground point (increases soundstage). if he uses two toroidals the second one would have to be standing up (vertically) so that magnetic influences are minimised. I'd then solder both wires from the windings together, then crimp with a connector and use a bus connector to connect to the pcb. that way you can modify in the future.
magnetically and static shielded is the way you'd want to go. and he may want to use magnetic wire instead of stranded. while he's at it he may want to replace any bridge recifiers with MUR801s (fast acting rectifiers). (opens up details).
Feb 9, 2003 at 12:41 AM Post #19 of 19
Wally I gather all info I can and give them to him (his name is Dimitris aka Jim )since I am the internet geek here
.He reckons that A-L/Plitron are superior to Nuvotem Talema,I think the Canadian company is closer to what he wants.Anyway he is going to decide the next couple of days since he wants to order at the end of the week.
(BTW with his order I will include a 30VA toroid to build a special PSU for your blue R50
