wmf
- Feb 3, 2010
how much better are the 701s over the 601s..
i REALLY liked those 601s ..
I will have to try the K701 for gaming some time soon, before I have to return them to their owner. Tomorrow is my birthday, so I will probably be out a bit over the next couple of days, so little opportunity to game.
The most commonly recommended phones to upgrade to from the AD700 are the K701 and the DT880. I have not heard the DT880 but I have an AD700 and a K701. The two share many similarities but I would say the K701 is a lot better.
A quick comparison from my experience, YMMV:
AD700 is more forward
AD700 has lusher sound. Mids aren't better actually, it's just that the K701 sounds so clean that the sound is "leaner" -- this is the same sound diff I heard comparing headphones through the Mustang and through the GoVibe Petite. The Mustang, which is so *clean* leaves a thinner, less lush sound compared to the Petite which adds a lot of lushness to the sound.
K701 has a much, much, MUCH larger soundstage. Almost unbelievable so. Hard to describe, you'll just know it when you hear it. This is the main upgrade the K701 has over the AD700, and IMO is the main unique strength of the K701 compared to all other dynamic headphones I've tried.
K701 goes down much lower and deeper in the low end. But only when using a good powered amp. Using the same good amp, a K701's low end is much better than the AD700's.
AD700 is a bit more sparkly in the highs. But overall sounds grainier than the K701
If this sounds good to you, and you're willing to burn in the K701 for a long time and willing to get a good amp for it, I'd say the K701 is a great upgrade. Mind you if you don't get a good amp for the K701, it will still sound great and can still match the AD700 easily. You'll still get the big soundstage for the most part; what you'll be missing out on is primarily the low end, and you may get sibilance or some harshness in the highs. But basically don't fret it too much if you don't have a really good amp. You can get the K701 now and use your uDAC just fine, then just get a beefier amp later on.
