Asterix
Banned
- Jul 6, 2004
What is the difference between a guitar amp and a hi-fi amp? What does 'overdrive' mean? Why do most guitar players prefer tubes? Thanks.
Originally Posted by rickcr42 Breaking down the guitar amp it is better considered as a highly specialised preamp stage or front end mated to a straight power amp stage with overall volume control.This last closer to a hi-fi amp than the first and in fact you can mate a guitar preamp front end to just about any power output amp,including a headphone amp. |
Originally Posted by dwc (btw I'm going to generalize heavily so pick apart at will.) To follow on to Rick's notes, the point about the two halves of the guitar amp is significant. To go along with the two gain sections are two types of distortion. Older amps have only have one volume control, the master volume. Newer amps often have two sets of volume controls, one set for each gain stage. That gives tha player independent control over the amount of distortion and the overall volume of their sound. In the "old days" if you played quiet you had clean tone and if you played loud you had a distorted tone. Today you can have distorted tone at "bedroom" volume levels through the use of distorted preamp stages. Overdriving the preamp stage gives a certain type of distortion tone. Overdriving the input stage is often done with a signal boost pedal of one type or another. For me a good example of this preamp distortion would be Joe Satriani's sound. Very smooth and liquid sounding fuzz. He can acheive distorted tones at low volumes, because the distortion is happening in the preamp section. Overdriving the output tubes gives a different set of sound characteristics. For a prime example of this check out vintage ac/dc. ("let there be rock", for example) You will notice that when Angus plays quiet passages, his guitar tone cleans up. When he plays louder (strums harder) the sound distorts. In order to get this tone you have to turn up the master volume the point where the output tubes generate the distortion. You can then buy a "power brake" to absorb the volume before it hits your speaker, or put your speaker in a sealed box, or cover it with blakets, etc, etc. anyway that's probably enough info to get me in trouble. Dan |
I have a guitar tube amp at home, and even though I don't turn it up loud enough for power amp distortion, I still find that it sounds better then pretty much any solid state I've heard. |
