aos
May one day solve the Mystery of the Whoosh
- Jun 21, 2001
Actually my DAC uses the same amplifier topology as META42. There would be no point in getting separate META42 if you had my DAC, except if you want to add crossfeed.
META42 has the benefit of larger dedicated board however, while my amp is optimized for size. This allows them to use bigger capacitors, different types of pots, and current sources to bias opamps into class A, although for AD8610 that doesn't seem too important. In any case, META42 has potential to sound better and potential to do mods.
However, for the very best sound you'd want to make full dual mono ala Blockhead, and for that you need elaborate external power supplies (possibly more complex than the amp itself), and it wouldn't make sense to use single EL2001, you should parallel couple of them or use EL2008/2009, so that you can supply large current to the headphones. All that would raise price (and size) through the roof. If you optimize for size however you have to make compromises. After all, in my case amp AND dac fit on 3 by 3 inch PCB!
