What do you think must have headphones in a collection are?
- Thread starter chef8489
chef8489
- Jul 1, 2005
I dont think the m40x have ever been on my list of must have headphones.M40x
bagwell359
HD-600 for the timbre. HE-6 SE v2 as the daily. K702 for the big image.
bagwell359
on the higher end:
Audeze LCD-4 (OG)
HFM Susvara
ZMF Auteur
Senn 800 (OG-mods)
Senn 600
Audeze LCD-4 (OG)
HFM Susvara
ZMF Auteur
Senn 800 (OG-mods)
Senn 600
Mhog55
Ibasso SR2 is a headphone everyone should attempt to hear imo. Build quality and sonic performance far exceed the price tag - by a mile.
r343
- Nov 29, 2016
HD6XX/HD650 is must have, you can plow trough those crappy vhs rips and live recordings without fear of death from youtube.
audioandy
- Apr 24, 2013
Damn, the Aeons do not belong in a "must have" collection, enjoy manually rolling your $500 headphone pads back into shape every time you want to listen to them. For planars from DCA instead go with the Ethers, more comfortable, also closed back, and don't have the notorious foam rolling pad issue.a pair of Dan Clark Aeon open X
Yes to the Elex, identical to Clears except they don't have the terrible design of gray cloth which absorbs skin oil and becomes visibly discolored. The Clears are fantastic headphones.
I have the LCD-X and they sound quite juicy minus the infamous midrange dip, but the weight is unacceptable. LCD-2c are a little lighter but it's pretty dumb, there's no benefit to the bulk.
Hard to say anything else without knowing preferences (price range, open vs closed, wires or wireless).
chef8489
- Jul 1, 2005
Not everyone has issues with the pads, and even if the pads wrinkle a bit it's not a big deal as it doesn't effect the sound.
As far as the lcd. I much prefer the 2c over the x sound signature and owned them prior. The weight isn't a big deal and again it's not an issue for me or many people. The quality and sound of these headphones are well worth the slight weight increase over other headphones. So no many of us don't think they are dumb and love the audeze headphones.
If you had read my initial post you would had noticed I mentioned a tube amp with a multibit dac, so there is no reason wireless headphones would be in here. You still can't get true lossless with wireless.
audioandy
- Apr 24, 2013
It's not a "wrinkle" and yes, it can affect the seal. Hopefully yours don't get it, i'm on my 3rd set of pads, all have gotten it.if the pads wrinkle a bit it's not a big deal as it doesn't effect the sound.
Ah, I don't know much about tube amps (didn't know the Lyr 3 is a tube amp) because they reduce audio fidelity.If you had read my initial post you would had noticed I mentioned a tube amp with a multibit dac, so there is no reason wireless headphones would be in here. You still can't get true lossless with wireless.
Fair. I would still consider the Airpod Max as a contender on a "must have" list. I for sure know i can't hear above 256kbps quality. If you can and that's why you prefer not to have wireless then I wonder why a tube amp, as that has a lot more audible distortion.You still can't get true lossless with wireless.
chef8489
- Jul 1, 2005
It's a hybrid tube amp. The point of it is I can throw a list solid state module in there if I want and run it as a solid state amp. I can add vintage tubes and change the sound with each tune as I want and make it warmer or more analytical or neutral if I choose. Not all tubes add distortion.It's not a "wrinkle" and yes, it can affect the seal. Hopefully yours don't get it, i'm on my 3rd set of pads, all have gotten it.
Runrunsmithfly
Previously known as ssmith3046
I'd say a pair of Sennheiser HD600 headphones.
bagwell359
It's a hybrid and stands up at its price as superior to many many SS amps.Ah, I don't know much about tube amps (didn't know the Lyr 3 is a tube amp) because they reduce audio fidelity.
chef8489
- Jul 1, 2005
Exactly..It's a hybrid and stands up at its price as superior to many many SS amps.
I vote HD600 also. Got to have one. And no, not 6xx, 650, 660s, 58x etc.
HD600.
HD600.
Gavanater7
If you are having a collection of headphones like me I recommend having multiple sound signatures. Bright, neutral, dark, bassy, V shaped, W shaped, U shaped, midrange n shaped. An open and closed version of each sound signature. Plus a specialty headphones a decent anc for travel, electrostatics cause it's a different type of experience. Hm if you still want more try different drivers start with Biodynamic, neodymium dynamic, beryllium drivers, planar fazor, planar stealth, graphene drivers, etc.
