sacd lover
- Aug 31, 2002
The Lavry and Apogee are principally dacs not amps. Would these qualify as high end designs .... not to me. The Lavry is average sounding at best from the times I have used the unit. In no way does the Lavry compare to the better amps I have hear regularly. I have no experience with the Apogee.
A switched-mode power supply, switching-mode power supply or SMPS, is an electronic power supply unit (PSU) that incorporates a switching regulator. While a linear regulator uses a transistor biased in its active region to specify an output voltage, an SMPS actively switches a transistor between full saturation and full cutoff at a high rate. The resulting rectangular waveform is then passed through a low-pass filter (typically an inductor and capacitor) to achieve an approximated output voltage. Advantages of this method include smaller size, better power efficiency, and lower heat generation. Disadvantages include the fact that SMPSs are generally more complex than linear supplies, generate high-frequency electrical noise that may need to be carefully suppressed, and have a characteristic ripple voltage at the switching frequency.
Radio frequency interference — The current in SMPSs is switched on and off sharply, and contains a large proportion of high frequency spectral components. Long wires between the components may reduce the high frequency filter efficiency provided by the capacitors at the inlet and outlet. This high-frequency current can generate undesirable electromagnetic interference. EMI filters and RF shielding are needed to reduce the disruptive interference. Linear PSUs generally do not produce interference, and are used to supply power where radio interference must not occur.
Originally Posted by slwiser /img/forum/go_quote.gif For a start would you consider either the Lavry DA10 or Apogee miniDAC for both have these switching power supplies. We will go up from here. ![]() |
