Originally Posted by White Knight
I just used Sony Connect online music store. I got a code from McDonald. Well I downloaded their software, I think it was 19MB, I bought one song and it says the codec was ATRAC3. The software was unstable on my W2k system. The software crash twice.
If you want stability, come to my forums and I'll assist you in correcting the crash(es); just open a thread. Otherwise [assuming you'll probably never use the program again], take it with a grain of salt. There are many variables which probably induced the error and I can attest that Sonicstage 2 runs 100% perfectly on my computer at home in the same scenario [win xp being the only difference].
Originally Posted by bangraman
True. There is a slight spoiler in there in that even though it is PCM, it still has a Sonicstage DRM wrapper.
They just don't learn where to stop, do they? @#$%
However, while ATRAC3+ 256K is notably better as redshifter says and indeed extremely difficult to tell from the original CD, in terms of sound quality and storage 'density' in general use there is little to differentiate it from 256K VBR MP3.
Right. Thank you for clearing that up - I really know nothing more about the other encoding processes in this existance as I wish not to get sucked into such haberdash [I've seen what that pursuit does to a man]! Are the other comprable encodings the same way with 'density'?
Originally Posted by redshifter
i think it's sonicstage 2.0, but i'll have to check (the disc came with my sony d-ne300).
Yipes! Uninstall that like so:
1. Uninstall all OpenMG related software via the Add/Remove Programs control panel and reboot as necessary. This means, OpenMG 2.2, related 'Limited Patches' and the 'Secure Module', SonicStage, Simple Burner, and RealOne. Make sure that you unplug your unit.
2. If you run Windows XP, proceed to delete directories within '\Program Files\All Users\Application Data\Sony Corporation' '\Program Files\Common Files\Sony Shared' '\Program Files\Sony' relating to OpenMG.
3. Start -> Run -> regedit. The 'Registry Editor' utility should appear on your screen. Delete the references to OpenMG located under 'HKEY_CURRENT_USER\Software\Sony Corporation' and 'HKEY_LOCAL_MACHINE\Software\Sony Corporation' by right-clicking on the entries
..and download iceeedtea's wonderful build of SS2 [
here]. AFAIK, your device's drivers are included. I really like his version compared to the other flavors..
