a44100Hz
- Dec 17, 2015
CD quality is CD quality. It does not matter whether it's coming out of a fancy dancy hifi rig or a $20 mp3 player. Period. The work of converting the file to audible sound is done by the DAC and amplifier. It is a discrete set of 1s and 0s, so unless you think the file itself is somehow different coming off a file in a DAP versus off a CD (which is literally just another medium holding a digital audio file) I'm not sure what to tell you. CDs aren't like vinyl, the audio isn't etched into the surface itself, it's basically a flash drive that needs an optical reader.
Expensive DAPs are what they are because they have really burly internal amplifiers and DACs as well as the parts to play higher fidelity files, but if you're outboarding the work to an external amp/DAC like the Mojo it doesn't matter if you're using the most expensive player on the market or something you got in a cereal box because literally ALL of the work in converting that digital file into an audio signal is being done externally and you've converted the player itself to nothing more than a storage device.
You're arguing with the wrong guy. He agrees with you.
