LamerDeluxe (tm)
Just came across this while digging through the archives:
http://www.pwrplant.com/cd.html
4 volt (yup, it's a lead battery), 3.2Ah, size of a jewel case, so just slightly longer than a d-25s for instance. Form factor is a bit like the BP-100, but this one should last about three times longer I think.
You'd need to fashion some kind of cable connecting the battery's connector to the battery terminal for a BP2ex. Maybe even some kind of wooden block, roughly the shape of the BP2ex, put two screws in it with wires attached.
And then maybe a way to attach the battery to the PCDP, a piece of velcro or something like that. When done well it probably wouldn't look too bad and be quite portable, like a BP-100.
