Cheeser5
- Aug 28, 2007
The only problem you may run into with such old electronics is static. Since all pots and other adjustments are prone to getting dust in them they can make noise, sometimes even when they aren't being moved.
Old speakers can be cheap, but most have foam surrounds that are either already broken or near doing so. If you had to set a budget for speakers or cans what would it be? Perhaps you can find something made within the last 10 years or so that would be more fitting to your applications.
![smily_headphones1.gif](http://www.head-fi.org/forums/images/smilies/smily_headphones1.gif)
