dokebi
- Mar 25, 2002
What is the gain of your amp? When I had the gains on my amps set ideal for low impedance hp's it wasn't adequate for my hd580's.
Originally Posted by mega Well, i did put the volume tab all the way up, and now its fine. |
Originally Posted by mega I ahve no idea what the gain of my amp is....its the standard pimeta from headsave. I have the specs that norm has given me... Gain setting to individual requirements |
Originally Posted by mega I was on the futuremark boards to get some different views...and this is what one member posted: Re: Any sound gurus/audiophiles...come in here! A different sound card would not make a difference. It may, it's circumstantial. The reason you're not hearing a difference is because there isn't much of a difference to be heard. Contrary to what the folks at head-fi.com got you to believe, you don't necessarily need or would even want a headphone amplifier. And about the volume, the Pimeta isn't exactly all that powerful. If the output voltage gain on the amplifier can be maxed with typical standard input voltage, a sound card with more powerful output would not give any improvement in power as the output of the amplifier has already been peaked. However a sound card with lower output impedance would make a difference given the amplifier is not being used. It's also realistic to assume that the headphones may potentially get louder hooked up directly to the sound card if it has higher output current than the amplifier, which would be the result of a lower output impedance. In which case, your little ol headphone amplifier would be useless. If you really need them to get louder, you will obviously need a more powerful amp. Any comments? |
Originally Posted by mega Can you tell me how to remove the ear peices safley? I don't want to risk damaging the cans...so any help would be nice. Also, are there any disadvantages of removing the pads in the inside? |
