Weird Static/Echo noise....
Jul 17, 2013 at 1:17 AM Thread Starter Post #1 of 7
Xlerator
I'm currently using the Beyerdynamic DT770 Pro 80 Ohm. On the left one, I can hear like a static and echo noise. I've heard it is a bad cable but, I've only had these for like 1 month. It is currently plug directly into my computer's default audio jack. Any suggestions? If its a bad cable how will I replace it?
Jul 17, 2013 at 1:22 AM Post #2 of 7
Try a different source, like your phone.
Jul 17, 2013 at 1:44 AM Post #5 of 7
Default audio jack? Do you mean your computer case's front panel jack or do you mean the one in back coming out from your motherboard/sound card? Have you tried both? Usually one is noisier than the other.
If it's the front panel, you might want to try what was suggested in another forum:
http://www.techpowerup.com/forums/showthread.php?t=187276
