youurayy
- Aug 7, 2016
Hi all / first post,
my main setup is a computer video card connected to a SONY STR-DN1030 receiver via a HDMI cable. This connection is perfect and noiseless, whether I output into 7.2 or into headphones directly from the receiver.
Recently I added a 2-channel tube amp with 2x RCA stereo input, which, when driven e.g. from iPad, also has no noise (besides the nice tube background hum.
Now, when I connect the receiver (from the headphone jack) to the tube amp (2x RCA), __and__ the computer is running (it must be on), there is a background noise in the connection.
When the computer is turned off (e.g. when playing a movie from a Blu Ray through the receiver), the noise is gone.
Another point -- the noise has diminished a lot when I replaced a: "6.35mm adapter -> 3.5mm headphone jack to 2x RCA cable" -- with -- "6.35mm jack to 2x RCA adapter -> 2x RCA line cable" -- but has not gone away entirely.
How to solve this?
I know a separate DAC will most likely solve this, but I'd like to be able to feed the tube amp directly from the receiver on occasion.
I don't really understand what's happening here, because even when the computer is on, the moment I disconnect the cable from the receiver, the noise is gone.
Let me just repeat -- when the computer is ON and I plug the headphones directly into the receiver -- there is no noise whatsoever -- zero. Only the the tube amp is susceptible to it, and only when connected into the headphone jack of the receiver, and only when the computer is on.
Help appreciated,
youurayy
EDIT: there's no other way to output a line from the STR-DN1030, the purpose of the only other audio-out (2x RCA) on the receiver is to connect it into another receiver in "party mode", and then it can only output the sounds it originates (e.g. playing from a USB key or radio).
How to solve this?
Help appreciated,
youurayy
