DaKi][er
- Jul 28, 2003
I got a mint amp here, with your standard component values, ad8620, 2*9v batteries, 470uf 16v pana fc's, 1uf blocking caps, etc.
It all works perfectly fine, 0 offset on both channels except for one little annoying thing... with the Panasonic pot between 2&3 o'clock positions and only at this position, the dc offset spikes to 430-470mV
I’m just completely puzzled to why it would be doing this, I can’t find or think of a single reason it could be doing this, how can dc get in from the pot when there are caps right after it that will block it?
I’m going to remove the pot and measure it, but their a pain the bum to remove and get another in there (tangent- maybe on your next run of boards, you should increase the hole size up a notch)
