Trissypud
- Jul 22, 2016
So basically I feel like my headphones are much more quiet than they should be and I thought this was to do with cables and power. But while editing a video in premiere pro I ran into an error and had to change sound class in the audio hardware preference tab. By default this was set as MME but to fix the issue I changed it to ASIO. As a result of this my Headphones were much, much louder than they usually are without too big of a drop in quality at higher volumes. It seemed to bypass the audio limit of everything else so I was wondering if it would be possible to apply this to all applications through some sort of setting. Thanks for any help
Some specs:
Windows 10
Sound card: Asus Xonar DSX
Headphones: Astro A40 tr
Some specs:
Windows 10
