Rob Watts
Member of the Trade: Chord Electronics
- Apr 1, 2014
It seems I don't need to add much!
To summarise - don't bother with audiophile USB cables, they either sound the same as certified generic class 2 USB cables, or they sound worse by creating more RF noise thus giving the false impression of better transparency. The extra RF noise gets into the DAC and then creates more noise floor modulation. Also, optical is the best digital connection, use KableDirekt - they sound identical to glass fibre, and are inexpensive, and works at 5m at 192k. USB can sound as good as optical, but it depends upon how noisy the source is. Use a mobile phone, or a battery powered laptop as your reference source, with of course an app that provides bit perfect data. Don't be tempted with USB re-clockers etc, as they again increase RF noise and then give the false impression of better transparency.
Give the Wave cables a go, I use Stream, as they do work and sound better for the Hugo M scaler to DAC connection. And using a powerbank on the M scaler eliminated the need for the Wave cables - but this was with optical feeding the Hugo M scaler.
