I don't know where you are getting the numbers for dCS Bartok, but looking at dCS website they quote:
residual noise
24-bit data: Better than –113dB0, 20Hz - 20kHz unweighted. (6V output setting)
That number is flat, so AWt would be around -116dB or nearly 4 times more noise than TT2.
As to your assertion that Bartok will drive anything, then again look at their specs:
headphone outputs
1 stereo balanced pair on 1x 4-way male XLR connector. 1 stereo unbalanced pair on 1x 6.35mm (1/4”) 3-pole jack. Full-scale output levels are 1.4W rms into 33Ω, 0.15W rms into 300Ω. Output levels are 0, -10, -20, -30dB, set in the menu. Minimum headphone impedance is 33Ω.
So you can't use a load below 33 ohms! Also, 33 ohms is only 1.4W - against TT2's 10W into 33 (balanced OP). Dave will match Bartok in drive from the SE headphone OP, but can deliver 0.5A RMS so will drive loads down to 8 ohms.
SNR or residual noise of -127 dB is perfectly fine, and will not create SQ problems - so long as the noise is fixed. But of course all non chord DACs do not have a fixed noise level, as it increases with higher signal voltages. Chord DACs are unique in that the noise is fixed - no noise floor modulation, and this has huge SQ benefits. I could easily improve the noise levels - but to do so would increase distortion. I am not prepared to sacrifice sound quality for meaningless specs, as 127 dB is inaudible.
As to what I do in the future - it will be governed by one simple rule - whatever works best for the best sound quality. If that's one box or ten, then so be it. I am not prepared to sacrifice SQ to suit convenience - and if you want convenience then there are plenty of other alternatives open to you.
Thanks for your response and explanations of some of the tech spec facts I asked about Rob. I did not ask them out of any malice ,but as always simply out of curiosity.
But what about ALL the other questions I asked?????
I am quite certain I am not the only one here ,yearning for some good news!
Or is there no News?
Regarding the SNR for Bartok and TT2 I just quoted the numbers mentioned in the just published comparison review over at headphonics.
And whether Bartok can drive Susvara to my satisfaction or not I don´t have a clue yet.
Sloppy of me, to quote without fact-checking yes.
Mea culpa.
But I do know that Dave on its own can NOT drive Susvara with some of the non compressed classical masterfile material I mainly tend to listen to.
And I still don´t understand, if as you say you could "easily improve noise levels "why would that also have to involve increased distortion?
How can 355 dB "down under details" be resolved with 127dB SNR?
As far as whether convenience or SQ rule for me, suffice to say: I would not have not been dragging along both my Qutest and Mscaler and BNC cabling and two headphone amps and two quite good headphones on all of my recent years long term 5-6 months spells in Asia until Corona hit if convenience had been my main preference.
Last year I came back to Europe this week.
Until I hear something better,either from you, or the competition, Mscaler rules for me.
I have to paraphrase Simon and Garfunkel :"Mama don´ t, Mama don´t take my Kodachrome away"
Or more frankly, please don´t make the Mscaler redundant ,just add more of its magic even if it takes adding even more boxes and cables!
Talking Linn, my ancient Linn Sondek LP12 is still working after more than 40 years and can still challenge some of the digital competition too!
But my Hugo 1 sits idle except for an occasional YT music video via headphones.
And now over to those other questions, please.
Cheers CC
