uzi2
- Sep 27, 2013
Interesting, I am sure that is counterintuitive to most of us, who would think that a shorter cable has less exposure to RF noise.
I have to say I find incredible, and very disappointing, that as the designer of the M Scaler, the TT2 and the DAVE you have to use a £1410 third-party cable to connect them to get the best performance. Are you happy about that? Do you think that £1410 is a fair price for these cables?Yes it was definitely odd using longer cables! Once you use solid core ferrites, length doesn't matter. And the reason is the common mode impedance - or rather the RF impedance of the ground connections from the M scaler to the DAC. Adding 2GHz ferrites increases this impedance. Adding longer cables also increases this impedance - doubling the length doubles the inductance, which halves the circulating ground currents - and its these ground currents going into the DAC ground plane that is the problem.
Like Rob, I also did the comparison with longer cables and can confirm that I heard an improvement with longer cables but to my ears that improvement was subtle compared to adding ferrites.
Would using a 2Ghz ferrite on the DC power cables have a similar effect ?
If so, the relatively thin power cable could be looped through several times ... or am I missing something ...
also I’d be interested in your opinion on the optimum length of Spdif cables ... some say short, some a 1.3 metre minimum ..
while I’m at it I must add thanks for the hard work, had my Qutest DAC plus MScaler for a month now and I’m listening to more music than ever ...
soundstage and detail is impressive enough but the sound of acoustic instruments is something else ...
It's always difficult to put numbers on the scale of changes, as often one hears a tiny improvement in the scheme of things, but it gets transformed into a huge change. Often when I am doing depth AB listening tests, the organ objectively sounds a little further away on A say; but when actually listening a little further away becomes B is as flat as a pancake, and A is cavernous depth perception. But I would say that a 2m cable over 1m is about 25-33% the improvement from using GHz solid core ferrites.
