Walnut Hi-Fi V2 WAV (& MP3) Player by wt - :ok_hand: screenless budget killer combo DAP/Amp :ok_hand:
Feb 17, 2017 at 8:31 AM Post #2,086 of 3,631
hi all how do i know if i have inserted the opamp correctly??
sorry i am a noob in these kind of things.. Senpais teach me :frowning2:
The AD825 i inserted seems to be sticking out abit more than the stock opamp but i cant press it in any further lol. is this fine?
Feb 17, 2017 at 10:40 AM Post #2,087 of 3,631
Hi all. First time posting! Was a long time lurker but getting a walnut v2 made me want to create an account.
I'm very happy that I bought this tiny wonderful thing. I've been reading the thread and got excited about op amps and rolling and bought the muses 01 and muses 02. I have a question about the AD825 amps can I get them already soldered on those board things? The only ones I see in Aliexpress are just the chips themselves not connected to anything.
Also Silverre I believe you got yours in correctly the semi-circle on the chip should align with the semi-circle on the board.
Feb 17, 2017 at 12:27 PM Post #2,088 of 3,631
Welcome to the board man! Happy to have you here :)
Any chip that is a dual opamp sould work. I think ad825 is mono because i see some boards with two of them on one DIP adapter.
BTW I actually ordered some BA IEMs. Will have to hear firsthand how they are off the Walnut...
Feb 17, 2017 at 12:39 PM Post #2,089 of 3,631
You should also get iem with multiple BA to make the issue even more obvious XD
Feb 17, 2017 at 1:09 PM Post #2,091 of 3,631
Stick to 8 pin DIP packages and you have less issues. If you want to play with SIPs then you can buy something pre-made or get an adapter/daughter board and build it yourself.
Feb 17, 2017 at 1:18 PM Post #2,092 of 3,631
is there a dual version of AD825?
Feb 17, 2017 at 5:02 PM Post #2,099 of 3,631
  I don't see a link to the tool to pull out opamp's in the first post? Someone posted a link a while ago in this thread.
Got one here
https://www.creatroninc.com/product/ic-extractor/?search_query=dip+ic+extractor&results=2
Feb 17, 2017 at 5:02 PM Post #2,100 of 3,631
