Joohunta
- Dec 16, 2011
Hihi guys i recently bought an upgrade cable for my 4Rs from jaben singapore and after a few hours into using it, the right earpiece just died and nothing came out of it( well basically i had to wiggle it for sound to come out) , so i figured it was the cables connection problem and switched the L side of the cable to the right earpiece....but to my dismay still NO (or very little) sound.
So then by now most of you would have figured by then that it's the earpiece's problem right? Well i thought so too but the wierd thing, is that the earpieces work PERFECTLY FINE on my stock cables.
So guys im in a serious dilemma... is my new cable faulty? or does the problem lie within my W4R earpieces??
