Digeeedad
- Jul 29, 2012
After a few years of only using headphones, I recently bought some active/amplified desktop speakers. Needing some advice on setting volume levels of 3 components in a connected chain. Any help/explanation would be greatly appreciated.
PC/Windows 10
JDS Labs El DAC II
JDS Labs El Amp II
Beyerdynamic DT 1990 Pro headphones
Vanatoo Transparent Zero desktop speakers (just added)
My question involves the volume settings on the PC, the JDS Labs El Amp II and that on the Vanatoo Transparent Zeros. The connection chain is PC > JDS Labs Amp II and DAC II via USB > Transparent Zeros via analog pre-amp outputs on the JDS Amp. All have volume/gain controls making 3 volume settings necessary. I will be using the volume control on the JDS Amp to adjust the volume of the speakers. I assume that I would adjust the main output volume of the PC and leave that static, as well as the volume knob, on the speakers left static. Any suggestions as to the volume level for the computer and speakers? Right now I have the computer volume set to 75%, the speaker volume set at 50% and the JDS amp varied as to desired listening volume. Is there any rule of thumb for these volume settings?
Thanks
PC/Windows 10
JDS Labs El DAC II
JDS Labs El Amp II
Thanks
