waytoodeep03
- Jan 16, 2008
I just picked up the A816 yesterday and took it for a test at the gym. One thing I noticed is that on normal setting this thing is VERY loud. However, there isnt much bass to my liking on the normal setting.
I go inside to the EQ section and none of the presets are too my liking so I use the Custom sounds. I got the sound I wanted out of it but my volume is cut extremely low on all custom EQ levels? What the heck happened? Why is the normal setting so extremely loud but I cannot get any custom sound to be as loud? Not only that but between level 20-30 there is almost no noticeable difference in volume.
Is there a way that I can increase the Bass on the normal preset so that I can retain that same volume of the normal preset?
