Multi
- Mar 7, 2002
Hi guys,
I recently bought a used META42 (previously built by Subsonic) and it arrived w/ the volume knob off the rod, probably the screw broke in the mail.
Everything works great and sounds great but it's hard to twist the volume rod (pot?) sometimes so I'm trying to fix it. I tried to screw it on the rod thing, but there is no screwhead in the volume knob's hole.
So I found a small screw and tried to screw it in and noticed a larger sized screw (6-32 according the website) moving in and out in the inner diameter, however it won't move if pressed against the rod (probably because the small screw doesn't exatly fit or something).
So what can I do? Do I have to go pick up a screw or a whole new knob?
The knob as posted by Subsonic a while ago is : Kilo ML series (digikey 226-4002-ND)
Thanks for you help!
