Violectric V222 and V202
May 25, 2024 at 2:14 PM Post #1,906 of 1,959
Is anyone else getting static shocks when touching your v222? I can get it touching the amp casing or metallic parts of my headphones.
No issues with noise in my living room I dare to say though after a month
May 25, 2024 at 2:51 PM Post #1,907 of 1,959
Whats your humidity like in your room?
I've never experienced shocks touching my v226, but I've had some instances of static pops in my planar headphones when the humidity in the room was very low (probably 30% or less) and I was moving around wearing static-y clothes. I got a humidifier and it seemed to alleviate it.
May 25, 2024 at 3:02 PM Post #1,908 of 1,959
No idea but live in northern sweden so likely quite low. Summer now though so its not extreme :)
May 25, 2024 at 4:07 PM Post #1,909 of 1,959
Not me. Of course in SW Florida with humidity 68% it would be tough.
May 25, 2024 at 7:26 PM Post #1,910 of 1,959
No shocks here and I live in a high humidity location. Question to ask is if your V222 has voltage on the chassis and is therefore faulty or if you have voltage that is discharging through the case of the amp to earth. It's most likely the latter. Easiest way to test is to put another metal box device with earthed chassis next to it and each time you are going to touch the V222 touch the other device first, if you get the zap touching the other device then you are discharging through the amp and should consider how to remove static from yourself. If you touch the other device and no zap then touch the V222 and get a zap it's time to call the warranty line for support.
May 26, 2024 at 8:26 AM Post #1,911 of 1,959
That shouldn't happen as the case is grounded. If you wear a lot synthetic fibers or similar then it might be that you are building up static and discharging through the case. Try to take a multimeter and find a conductive point on the case (set it to resistance and put both pins on a conductive point), then check that you can get a closed loop from that resistive point to the ground (the middle pin on the IEC-13) in the power connector of your amp. The screws f. ex. are conductive so they should be connected to ground output. I am making the assumption that the amp is connected properly to a grounded outlet in your home.
May 29, 2024 at 5:30 PM Post #1,914 of 1,959
Here is the info for those that don't want to go looking for it.
  • HPA V322-E.pdf
  • HPA V324-E.pdf
May 30, 2024 at 10:14 PM Post #1,915 of 1,959
My volumn knob is always close to max volumn when listening with the He6se (otherwise sound is not very loud), is it better to set the the pre-gain to +6 in order to keep the volumn knob closer to the 12 o'clock position? Thank you.
May 30, 2024 at 11:54 PM Post #1,916 of 1,959
Yes
May 31, 2024 at 12:59 AM Post #1,917 of 1,959
Thank you. I tested Pre-gain at 0, +6 and +12. At +6 I had to turn the volumn knob to 4 o'clock, at +12 and volumn positions at 12 o'clock it sounded best so far. Headphone is He6se
May 31, 2024 at 7:34 AM Post #1,918 of 1,959
The Pre-Gain should be set for a medium to medium high perceived volume (not deafening). Perfect as you did now, between 50 - 60% of the total rotation. I do the same with my V200 (now also for the Lehmann Linear).
Jun 1, 2024 at 11:32 AM Post #1,919 of 1,959
As I hinted in an earlier post, I rolled opamps in my V222. I understand that Violectric does not recommend this, but here are my findings.
Burson was kind enough to send me a free pair of their Vivid V6 opamps in exchange for an unbiased review. Now that I’ve put maybe 500 hundred hours on the V6s, I feel I can provide a full review.
The stock opamps were super simple to replace. You just remove the top 4 screws from the front and back of the V222. There’s a lot of real estate around the sockets, so it was easy to pull out the stock opamps and replace them with the V6s. Note that you need to use a chip puller to do this though (~$2).
However, there is one more socketed opamp, which looks like some sort of buffer after the volume pot. I intend to replace that with another V6, and will report back on what I hear. In the meantime though, I replaced it with a highly-regarded Muses 1, but it immediately sounded too thick and warm. The stock opamp had much greater transparency, so it went back in. I didn’t have any other issues with the combination of stock buffer opamp plus the two Vivid V6s.
First, some background on the V222; contrary to some folks here, I don’t find my V222 to be especially warm. I hear a neutral overall sound, driving bass, mellow treble, and just a touch of warmth. But I also hear a lot of midrange resolution – which I think is what folks are hearing as warmth.
I was initially concerned about changing the tonal balance of the V222; I liked it just the way it was. But it was apparent within a few minutes of listening that this worry was…nothing to worry about. Ie, I didn’t hear a change in tonality. But what I did hear was a dramatic increase in resolution across the entire frequency spectrum. Bass didn’t increase, but was more textured. Treble lost some grain that I didn’t realize was there with the stock opamps – making it simultaneously smoother, yet more detailed. But it is the midrange that really stood out; greater resolution meant greater musical detail. The midrange detail plus the grain-free treble allowed me to listen louder and peer more deeply into the music.
In terms of technicalities, the sense of stereo imaging was enhanced – I think due to a blacker background. This made individual instruments and sounds much easier to track. Soundstaging was dramatically improved as well. I don’t think the soundstage became larger, but it became more three dimensional, with greater depth and gobs of layering.
For example, Madonna’s recordings are always first rate. On Vogue, the V6s brought out even more atmosphere than I have ever heard in the song – projecting a grand, deep, holographic soundstage. On Crazy for You, Madonna’s voice is presented within a huge soundstage – starkly silky and resonant, yet surrounded by the decay of subtle echos. On The Verve’s History, the violins at the beginning of the track show off the midrange resolution and grain-free treble, before Richard Ashcroft’s voice starts in as clearly as I have ever heard.
All of this resolution meant that I could hear musical details more clearly than ever before. I could hear the presumably mistaken lone doubled-up beat at :20 into Bruce Springsteen’s I’m on Fire, and the pair of taps at the beginning of Bob Seger’s Turn the Page. It was truly mesmerizing to hear that deeply into songs I have heard throughout my life.
So is it worth it to add the V6s to the V222? Absolutely. The V222 is already a fantastic amp, but the V6s took this already fantastic amp and brought up its performance to a level I simply did not expect. Now I am looking forward to hearing what substituting one more V6 for that last stock opamp will do…
Does the op-amp near the RCA input matter if I only use XLR balanced input? Or should I roll both op-amps in the input stage?
Jun 1, 2024 at 1:59 PM Post #1,920 of 1,959
That is a good question. I do not know, and just assume it should be symmetrical, with both replaced. 🤔🤔
