Vibration sound in my MS-1's
Oct 1, 2007 at 2:24 AM Thread Starter Post #1 of 5
andrus
I've had my MS-1's for a few months now and recently, in the left headphone, I've noticed a slight vibration noise that's more apparent on some songs then others.. It's really pissing me off
, is there anything I can do to get rid of it?
Oct 1, 2007 at 11:58 AM Post #3 of 5
Yup; sounds like it could be a classic case of the Grado "Grattle" alright, where a piece of hair has found it's way into the driver. A quick forum search of the word "Grattle" should link you to lots of good advice and remedies.
I make it a point to check my pads at least once a day to make sure no hairs are stuck in there to cause a problem. It helps.
Dec 3, 2007 at 11:28 PM Post #5 of 5
I'm glad I found this thread so quickly. This saved me what could have been hours of troubleshooting and frustration. Thank you much!
My hair wasn't even all the way in, I pulled it out of the mesh with my fingers and away the grattle went!
