Very concrete questions for owners of Creative Zen
Apr 7, 2008 at 6:48 AM Thread Starter Post #1 of 4
yops
1-In the Underground? With the strong noise, does it defend itself well?
2-Quality sonorous cold?
3-Radio!!! Good receipt?
4-Duration of the battery? MP3 to 320kps all the time?
5-SD? If you have a SD with several CD recorded in folders can you listen each of the folders independently?
Thank you very much and regards!!!
Apr 8, 2008 at 6:22 AM Post #2 of 4
Up!!!
Nobody has a Creative Zen?
Please I need urgent response to my questions!!!
it is for a gift to a propietary of a Cowon D2 and we do not want to disappoint it with a badquality of breeding player!!!
Apr 11, 2008 at 3:02 AM Post #3 of 4
1. well, it depends very much on your earbuds, but the zen is loud enough.
2. if i get your question right, the zen sounds definitely "colder" than an ipod, e.g.. that is less muddy. it still sound warm in my ears though.
3. i only used the radio to check it out, it has good reception.
4. the battery life is ok but not spectacular for a flash-based player. you won't reach the advertised number of hours with 320kps (or any format).
5. yes.
Apr 11, 2008 at 4:45 AM Post #4 of 4
If the future owner already owns a Cowon D2, then he is probably going to find the SQ pretty bad. In fact, I'm looking to sell mine because of the pretty bad Build quality and okayish SQ.
If you want great SQ, get a sony NWZ A720 or A810.
