MikeW
- Nov 4, 2005
any experiance with the Cheaper Mundorf supreme line? They are less then half the cost of the silver. Also what about the size? Will the 1uf mundorf fit in the chasis with the lid closed, I hate to buy them and have to send them back or re-sale them because they don't fit, I don't want to put it in a new case or leave the top off. Right now was considering somthing like bypass the stock caps with a .22uf mundorf supreme. They are only 13$ ea. If the 1uf would fit they are about 20$ each. The silver series is more then double the cost. 1UF seems kind of weak if people all recomend 4.7 and the stock is 10uf.
or even the standard Mundorf MKP Series, you could easily fit a full 4.7UF in there. I don't have any idea how the MKP series sounds though.
Thanks for your input
mike
mike
