Friday morning I was very excited when finding all ordered parts in the post at once.
I just decided that it would be a weekend producing in my studio but one look at the packages and I changed plannes. It was time to update my Valab spaceship!
Tonights Setup:
The parts ready enter the spaceship:
Finished Close Up 1
Finished Close Up 2
Finished Overview
Unfortunately I didn't manage to solder the LT1084 with its heatsink from the board. I only had a hand vacuumpump at hand and it wasn't able to suck all the solder. I'll give that another try on monday at work where we have a professional desolderingstation.
These updates have been done tonight:
- Caps Mod: The power supply will be updated according to Bill's mod: 3x 1000uF BG FK's, 1x 220uF BG FK and 8x 47uF BG FK's for decoupling of the DAC chips. 8 Sanyo Os-Cons SP (low ESR) 100uF/20V will replace the caps in the digital circuit.
- 4 Vishay 11DQ10 Schottky Diodes will replace the original ones on the board.
Will be done later:
- Power supply upgrade. A 30VA toroidial transformer will come in place of the original one.
- The LT1084 will be replaced by the DEXA 7808 to reduce noise generated by the LT1084 (Attention: This requires rewiring of the DEXA as the pin-out is different).
- The 330R resistors of the I/V stage will be replaced by 340R 0,1% metal films for now. (might need to experiment more with different type of resistors)
- The Coax/Optical switch will we replaced by a relay so I can switch it from the front without extending the digital signal line all the way through the case.
- Last but not least I bought a nice Galaxy Maggiorato case at HIFI2000.it where the Valab will find its new home because the Caps & Transformer ain't gonna fit. Besides that I want to get rid of the cheapo look of the original Valab case. The Hifi2000 cases aren't expensive, have a good buildquality and look very nice.
Will update the rest later.
