h2rulz
- Nov 7, 2015
Is it a good idea to use a RCA splitter at a single input port of a receiver?
In theory, I'm thinking it'll work but just wanted to make sure there aren't any sound quality or gear damaging issues.
I have two headphone amps with preamp outs. The preamp outs are connected to individual inputs on my receiver that powers my speakers. I also have a Schiit Sys that I'm using in reverse to switch between the two amps, but I also have to use the receiver remote to switch the inputs on the receiver as well.
Then I thought, why not make my life easier buy only using the switch on the Sys to switch between the amps?
Will there be any problems connecting two sources into a single rca input on a receiver?
I do use both amps at the same time, often switching back and forth.
Thanks
Thanks
