Does a passive preamp raise source impedence as compared with a direct connection? |
There are different types of passive pre-amps (buffered, shunt, etc.), so it depends on what type of passive pre-amp we are talking about. Generally, a passive pre-amp lowers the impedance your source sees (which can be bad) and also raises the impedance your amp sees (which can also be bad). To reduce this problem, some passive pre-amps use a 10-20k pot in the schematic design. High impedance input amps (100k or so) are then used, so even if the pot were turned to its extreme, the amp would only see a maximum 10k (which is acceptable). However, a 10k pot at that same volume level would load the source, causing increased distortion (the source would see only a couple hundred ohms). Furthermore, I believe using a 20k pot attenuates the signal at full turn (max volume) by a couple of db (forget the exact number), so there is always a give and take with passive designs.
Longwinded answer, but to directly address your question-yes certain passive pre-amp designs raise the source impedance compared to a direct connection. Does this help answer your question?
In my opinon passive pre-amps are a good alternative if you can live with three shortcomings:
1. You need short interconnects (less than 1m) to prevent frequency rolloff and frequency phase inversion. Using a lower ohm pot lowers these problems, allowing for a longer interconnect, but has the side effect of signal attenuation.
2. You need an amplifier that has a high ohm input; 100k input impedance and above is the general rule.
3. Finding a passive design that would not load the source component.
I've always thought it would be a cool idea to build a shunt-type configured passive pre-amp with the outputs of a 1212/1820 in 10+ mode. The "hotter" +10 professional setting would reduce the attenuation caused by using a 10k or 20k pot. Cheap, easy, and only two resistors in the signal path!
Using the digital volume control is a quick and dirty way of ditching the active pre-amp and allowing a direct connection to the amp. As long as you don't attenuate the digital volume too much, you could end up (as others have explained) with a better sound than a passive volume control setup. If you found an amp with a high voltage input sensitivity, this could also be a very real scenario with audiophile results. Only drawback is you would not be able to crank the volume to extreme levels, but we're audiophiles not rockstars, right?
