Raymate
- Feb 28, 2004
Just want to know if this will work.
Linn Records have been giving away free tracks each day in Studio Master 24-bit some up to 192k and after using the ALAC file in iTunes I want to actually hear the sound as it should be.
Never been above CD quality source so this is all very exciting and sounds great on my E7 even with it downsampling the files to the E7
I currently have connected to my Mac a FIIO E9 with an E7 via USB, or course the E7 can only do 16 / 44
I'm going to buy the E17 soon anyway as I need another amp/dac for on the move.
If I plug in the E17 with USB into my Mac will it just work and send the files as is @ 192 or 88 etc. (some files are in 192, 88 and 44 but all are all 24 bit ALAC from Linns website)
Do I need to do anything special on the Mac?
Can my Mac (iMac and MacBook Pro) give audio out over USB at 24/192 or is there a limit for the USB output., would I need to use the optical out to give me up to 192 ?
Any one using Mac and iTunes with high res ALAC audio files like to comment please.
Thanks.
Thanks.
