using echo mona 24 now, where to go?
Jun 14, 2009 at 12:57 PM Thread Starter Post #1 of 2
GearGeek
my setup
main powerbook g4 --- echo mona 24 ---- srm-t1w ----stax lambda signature.
considering update , where to go?
some people consider this echo mona 24 to be really good~ I love it , but ever since i got my stax setup , the idea of getting something better just keep growing!
of course , pc hifi only , if i can not use my pc as source i wont post it it here anyway.
thanks a lot !
GearGeek
Jun 14, 2009 at 1:05 PM Post #2 of 2
The Mona sure is a great card, and you probably won't gain that much improvement with an up/sidegrade. The newer Echo AudioFires are excellent sound cards, their AKM DACs perform very impressively. Disclaimer: I've been an Echo fanboy for over 10 years, since the 1st generation Gina.
And if an AudioFire is too cheap for an upgrade, the $1000 RME Fireface 400 uses the same AKM CODECs inside.
